- 15 Sep 2005
Just putting together a new system using a Ryzen 9900x ... after install mboard, CPU and DDR5 I was running memtest86 to confirm that the RAM was ok ... tests passed fine but looking at the results saw it reporting min/max/av temps of 42/83/61 which seemed high - also at present BIOS reports temp of 45 while on the BIOS screen (nb memtest86 had RAM temps of 21/41/34 which seems more resonable) - CPU has a phantom spirit cooler and at present the case is fully open. By comparison on my 5800x3d PC memtest CPU temps were 32/71/49.
Quick google seems to suggest that 9900x temps are/can be high - are the figures I'm seeing "normal" for a 9900x or should I be looking at reseating the cooler etc!
