Ryzen DRAM calculator updated
16 Jun 2019
Leek staffordshire
to version 1.7.0
https://www.techpowerup.com/263451/dram-calculator-for-ryzen-by-1usmus-v1-7-0-released
https://www.gamersnexus.net/news-pc...nerability-amd-rdna2-gn-china-trip-in-the-air
  • Added functionality to read current memory timings for Zen 2 (AM4).
  • Added a memory bandwidth test (Read and Write).
  • Added an Inter-Core Latency test (AM4).
  • Improved the accuracy of Random and Custom latency test.
  • Some changes in the suggested CAD_BUS settings. This could offer a significant improvement in stability for configurations with two or more RAM modules.
  • VDDG setting is now divided into two independent settings: VDDG IOD and VDDG CCD voltage (as in AGESA 1004B bioses).
  • "Compare timings" now works for Zen 2 (AM4).
  • Added support for 3000 series Threadripper CPUs (Castle Peak).
  • Minor user experience GUI changes.
  • Added support for Hynix DJR (a new CJR revision that has backward compatibility with classic CJR).
  • Minor bugfixes
It's an interesting update.
Here is my previous config it told me:
Current: https://i.imgur.com/Z62VTh1.png
Previous: https://i.imgur.com/WJ3M1bM.png
Timings stayed the same but Soc voltage has taken a drastic decrease in favor of bumping up the VDDG voltages. Don't know if I agree with that. CADBusClkDrv in bottom right also went from 24 to 30
Not sure if these changes eek more stability than previous version but since the 1.0.04, it was greatly needed.
Yes, VDDG is very important for FCLK stabilisation.
That was the missing ingredent for me to get my CPU to stop crashing at 1800 FCLK.
I set VDDG to 1.0v and it's been happy for hundreds of hours since. (I did 165hrs in Odyssey alone at these settings)
It maybe false positve due it being new, however the archive contains a memspeed.exe which is picked up as a trojan/backdoor by various scanners.
The previous version 1.6 scan's cleanly.
Not seen anyone else mention this..
For example..
Alibaba
Backdoor:Win32/Generic.bdced989
Cylance
Unsafe
Microsoft
PUA:Win32/Presenoker
Qihoo-360
Win32/Backdoor.762
Can you go into more detail about how you did stability tests for FCLK? I had mines at 1866 and although it worked I had a brief freeze in a game so I went back to 1800.
Also I scanned memtest with windows defender and malwarebytes, no threats here.
I have used this for a few months now but I seem to remember that in the calculator the extreme settings hadn't been finished. Does anyone know when these will appear?
(and don't say when he has finished them!)
I can never get these to work, on my Corsair 3200 or my Ballistix Elite 3600 memory these settings either dont post or throw up loads of memtest errors.
People forget DRAM also has an advanced tab you can look at to configure further but yes, they rarely work. I've found copying every setting but setting geardown mode to enabled will always pass. I know this is now 1.5T Command rate but it still beats XMP almost always.
Also I don't want to insult anyone's intelligence but make sure you very clearly read the names of your settings and match them up to your motherboard. Most times it is in order but sometimes it's not, particularly on Asus boards.
For example: https://i.imgur.com/IGRdQaV.png
Does not match Asus order: https://i.imgur.com/09qVNZR.png
Write delay and read delay are swapped. Pay no attention to the numbers inputted in Asus screenshot, just quickly grabbed it from a random YouTube video.
I have an issue with the new version where it won't import the XMP profile. I would normally assume operator error, but I have no problem importing XMP into the old version.
I personally spend many days and hrs testing when Ryzen 3000 was released in July. If you already have your settings working fine, I don't think its worth messing with the values again.
I just wish bios creators and istmus would ALL use the same abreviations
Its like a quiz show for me trying to find the `correct`one to use :(
