Ryzen ideal temps
The R5 1600, which came with the beefier Spire cooler normally idles at 35c if ambient is around 24c. Not sure why AMD cheap out on the cooler for the 2600. You should see 37c idle. It can jump as high as 42c. As long as your load temp is below 80c - you are good. Do replace the paste if you plan to keep the stock cooler with something like MX-4.
Here is an alternative . . .
https://www.overclockers.co.uk/ante...-direct-contact-cpu-air-cooler-hs-017-an.html
Thanks 36 ish atm,son gave me a coolermaster hyper evo 212 cooler I think and just wondered if it was worth swapping
just tested now at 29 with the fans running @ just over 400 rpm @ idle, will do some testing later, sorry should have said i only had some old artic silver paste from years ago so it will be cleaned and new paste applied in the future
