Permabanned
- 29 Sep 2011
- melee island
If you have been overclocking with ryzen master and get into a system crash when the os has started..
go into the root folder of the ryzen master install folder and rename the .json file.
This has to be done in safe mode.
I've only just had to figure this out, not been forced to do it with other ryzen master overclocking fails but I did after disabling cores.
Hope this helps someone in the future. If that person is you, you are welcome
