Ryzen & Memory settings help
10 Apr 2015
Hungerford, UK, Earth
So ive built a system up using the parts below, how do i get the memory above 2133mhz, i tried setting it to just under 3000mhz there is no option for 3000 exactly.. but it boots up saying overclock failed and goes back to bios.
My basket at Overclockers UK:
Total: £412.97
(includes shipping: £0.00)
Update the Bios is key - early bios versions do not have wide DDR compatibility.
Once new bios is ready simply select DOCP (equivalent of Intel's XMP), so that the natural frequency can be found.
That ram will run 2933 with docp not 3000 this is not a native 100 bclk divider on am4 ryzen.
You may need to set gear down disable and 2T command rate with these none b die sticks.
Ive updated the BIOS and selected DOCP @ 3000mhz and all working. Havnt tried the PC under load though. Note this wont be overclocked.
