Ryzen ram speed help
6 Dec 2006
Barnsley
Hi all, anyone had any experience with Corsair CMU16GX4M2C3200C16 led red?
Putting together a b350-f and 1700 but want to know if anyone had/has the above ram and if hit 3200mhz?
Thanks
Thanks
If you want to play safe, then go with something on the QVL, however, ive just had a quick look myself and Corsair CMU32GX4M4C3400C16R is on the list, which is pretty close to what you are looking at buying, basically CMU16 is 16gb and CMU32 is 32gb, GX4M4 is 4 modules, GX2M2 is 2 modules, 3200 is the speed, 3400 is the speed of the kit they tried on the list, and both are C16 cas latency of 16, I would hazard a guess that the final R on the end actually means RED, not quite studied into reading Corsairs codes as I don't use their RAM myself.
G.Skill who I do use are easy to read, my kits are F4-3200C16D-16GTZR F4 is DDR4, 3200 is the speed, C16D is cas latency 16 Dual channel, 16 is the kit size and GTZR is G.Skill Trident Z RGB
The ram im using on my MSI motherboard isn't on the QVL either on the MSI website, but something was close to it, so I brought it anyway and works fine.
