Ryzen spec check
16 Nov 2008
Hi all,
Putting together a Ryzen build. Was hoping some helpful folks might take a quick look to see if everything seems in order.
I know its missing a GFX card, was planing to put in a GTX1060 6GB, but prices are silly at the moment
My basket at Overclockers UK:
Total: £913.64
(includes shipping: £20.82)
Thanks for any info/thoughts/recommendations etc.
Cheers,
sombaht
Thats is actually not bad, but if you could cut back on the case and keyboard+mouse a bit you could maybe just maybe get a 144Hz screen.
You also only need a 450-550W PSU.
Well i will probably be upgrading the CPU and ram at a later date so would like to have a PSU that will be up to the job. What kind of card would be needed for a 144 Hz screen?
Cheers,
Sombaht
A GTX1060 6GB or a RX580 8GB would be fine for a 1080P 144Hz screen.
Freesync for AMD and Gsync for Nvidia if you can afford one.
But even without Gsync or Freesync going from 60Hz to 144Hz is a big leap in terms of smoothness/fluidity etc.
