Ryzen tuned memory query
19 Jun 2020
Hi all :) Apologies if this question has been discussed previously.
I have just purchased the 'Ryzen tuned' Corsair Vengeance RGB 2X 8GB 3600MHZ ram for my new build which I have yet to start.
This will be paired with a Ryzen 3700x and I understand that AMD does recommend this memory speed. I have just noted that it is CAS18, where the recommended would be CAS16.
Before I unpack this I just wanted to ask if anyone could advise if I am likely to run in to any problems? Hopefully it being 'Ryzen tuned' will actually reduce any issues but I thought best to be sure before going ahead.
Thank you in advance for your help.
