Hi All,
Just needed a sanity check really, and to ask for some info on RAM/Mobo choices.
I've decided it's finally time to retire my i5-2500k setup and get something a little future proofed to last me hopefully another 5-6 years. I'm thinking Ryzen is my best bet. I've decided a Ryzen 5 1600X would be ideal for me.
Motherboard wise, I'm not sure if X370 would be more future proofed than a B350 - I've been looking at either the MSI B350 Gaming Pro Carbon or the Strix B350 boards, though I don't know if the extra for a X370 would be a wise choice for the future. What do you guys think?
RAM wise, I've been told to get 3200 RAM for Ryzen. I was looking at some with LED's but none of them seem to be feature on the board QVL lists. Does a Ryzen compatible 3200 LED kit exist? I'm ideally after 16GB so will need to be 2x8GB.
And finally, a cooler. I'd like my system to be quiet so I don't know if AIO would do the trick - I'd previously had a H105 and a Coolermaster Seidon 240 on my 2500k and they both seemed louder than my existing air cooler. I'm leaning towards something like the Cryorig H5. Would this be a good choice?
Thanks for any advice you can give.
