I bought a Ryzen 5 2600 which has the Wraith Stealth as the stock cooler included and so I went ahead and fire it into the new MB (MSI Tomahawk B450) and fired up the PC expecting the "hahah I never post first time" screen. Or the blank look my gf gives me when I ask her, well anything.....
Anyway it boots fine first time, Windows sorts itself from my previous install (i5-4690k), and away we go. I dont have any experience with AMD since way back when so I just leave things as they are settings wise and see where we are at. First things first is temps, around 45 idle and 70+ish at stress seemed a wee bit high to me but what do I know.
I did a load of other benchmarks but essentially the CPU was on a par with my 4690k gaming wise (although the Intel can be amazing at times) and destroyed it elsewhere (it's old), as expected. Temps were a lot higher than Intel, but then I did have an aftermarket cooler as anyone who buys a K series processor would. Not a great one tough, a CM Hyper 212 EVO, you know bog standard.
I plod along with the stock cooler, cause nothing is amiss but then a weird noise starts coming from my case, im thinking new CPU/fan lets have a look at these. I have reference points but they are all internet based. So i take some rudimentary readings and then think Ill use my old EVO 212. Reseat and resinstall the Ryzen with stock cooler, same deal.
Oh well it doesn't have an AM4 bracket but f'it I say, Ill just see what its like seated with new thermal paste and the like for reference. Turns out its still miles cooler, about 10, approaching 15 degrees at idle. easily 10 under load. This is an UNSEATED heat-sink/fan set on very low RPM. Temp wise its night and day against an ancient and not very expensive AM cooler, but noise (currently 30C)? The noise is still there! Hence its a GPU fan problem and that I shall take elsewhere!
Does anyone else have similar experience with the stock 2600 cooler being SO bad, cooling wise, really liking the chip given what I paid. ? I was willing to let it slide as hey its just me, ive changed platforms and im not sure of what to expect.
