S 939 System Problem - Help
31 Oct 2007
Gods County(Allegedly)
A few yrs ago gave my son my old system.
x2 3800 (clocked to 2.4)+ 2x512mb ram + 2 x 80gb Maxtor h.d's running raid '0'+ 8800gt gpu+dvd re-wrter drive - all on an Asus A8N-SLi Se 'board. O.S. - XP Home
No problems whatsoever until this weekend.
Sons away @ uni. and his comp does not get used much, if at all , while away. Probably been about a month since it was touched when on Saturday looked to switch on (wanted to test a h.d on it...) when it dawned that it was not booting.
Boiling it all down ; cmos battery had failed.
No problem - just install a new battery:). Done ...but still not booting.:(
Look out manual - to adjust bios to allow for raid etc BUT NO overclock - and tried again ... No luck
After a no. of attempts finally got to the 'welcome' screen when got the message
windows will be shutting down as ' c\windows\system32\services.exe' was terminated unexpectedly.
Error code '1073741819'
Did a google but swamped with ref. to virus's etc - it's not a virus ; never on line on line etc and worked well day he went back to college
Advise anyone ?
Could simply repair windows?
Could Install on a.n.other drive (got a 250gb Hitachi going spare)
Or should I not waste my time and simply 'junk' it ?
perhaps your son broke it and decided not to say anything? :p
if you boot off the Xp disk, there should be a recovery console option somewhere along the installation process (cant remember exactly where, its been a while since ive installed XP outside of a VM, but if you get to the drive partitioning options, then you've gone too far), where you can run things like checkdisk and startup recovery tools
depending on the importance of what is on the drives i woudl just load failsafe defaults and do a clean xp install
sounds like it would be fine after that
Yes you could opt for a reinstallation of windows without overridding you files, just remember to select repair rather than a new installation. However, a clean install would be preferable with a fresh format of the drive, at least that way you know you are starting from fresh.
Thanks for the replies.
Tried to do a repair - guess what -windows cannot find a hard drive :(
Bios sees the raid array but windows cannot - unless i let it try to boot from hard drive when it finds it :rolleyes:
I believe that to repair I'll have to re-load the Raid driver (the press F6 if you want to install raid driver etc). Have got floppy but no floppy drive so will have to re-install floppy drive before trying repair tomorrow.
If I'm wrong in believing that it's the raid driver 'issue' - please let me know; to avoid wasting time.:D
Could , simply , install onto new HD - no raid etc. Obviously quicker but would lose data......
Am beginning to ? wether board or (one of) hard drive is fu.... ?
All this for a failed cmos battery?????
