It's not a bad case but make sure you can get a suitable PSU before buying*. The one in mine is only 190W and has a 20-pin mobo connctor rather than 24-pin. Oh, and the optional intake fan near the 5.25" bay is 38mm rather than 40mm. Tricky to find but might be needed to push a bit air at the HDD.
Thanks good to know.
Any ideas what PSU would fit?
is it a flexATX power supply?
Might be worth looking on the bay for a HP/Dell/etc small form factor PC PSU...
Yes, I believe it is.is it a flexATX power supply?
. I think they've moved away from that sort of thing with their normal desktop PCs but it's worth checking.
