S/PDIF Optical Speakers for PS3
13 May 2003
Hi Guys
I'm thinking of getting an LCD monitor to use with my PS3. I'll run it on HDMI but most of the monitors have crappy speakers so I was thinking of getting a 2.1 or 5.2 speaker set to play games. I could also then connect my PC to them too.
Now the only way I can see of doing this is to get a set of speakers driven from the Optical S/PDIF (toslink?) output of the PS3. The alternative is to feed the optical into the PC then out of my PC to the speakers but its not an elegant solution.
Can anyone recommend a set of speakers that take a optical input? I've been looking but short of trawling through every spec table on each speaker model (which I have done a little of already) it proving tricky to find suitable speakers.
Any help gratefull recieved.
can reccomend the z5500, they have direct 6 channel input from pc, and a optical you can use with the ps3, they also have a coaxial input aswell, bit expensive though
