Currently using a s10 (which has been great for the last couple of years) but looking to upgrade to a S21.
But unsure which model to go for, I want a bigger screen but is the ultra worth the premium over the plus ?
Cheers
Hi Callum, welcome to the forum.
Are you 100% set on the S21, does it have to be a Samsung?
I don't get much in the way of that on my S21U... but I also disable/ignore/remove most of the branded BS apps that come with the darn thing anyway.Aren't the newer Samsungs now rammed with adverts and whatnot? Or has that now been patched/opted out? It's one of the things that really put me off going Samsung past my current S9+.
