S21 5g screen protector
Not exactly what you asked for but a hybrid one is the best screen protector I've found for my s21.
Easy to apply and the screen fingerprint sensor works but is harder then a normal film protector, doesn't have that soft feel if you push your nail down on the screen.
Bought mine in September last year and looking closely now I still cant see a scratch on it.
EDIT* thinking now I probably took off the fingerprint security and then rescanned my fingerprint after applying the protector.
thankyou, will get one ordered
Just fitted one of these and can confirm fingerprint sensor still works, unlike the more expesive glass one i had before.
Took a bit of effort to get a couple of air bubbles out though, but found a credit card worked better than the supplied squeegee.
