S21+ loose usb-c port
nam
nam
18 Oct 2002
London
Hi,
seem to have a issue that any cable connection just does not sit correctly and cable has to be held in place. Did a port clean but still the same I assume that it's not a warranty replacement and have read its a common issue. Anyone else experienced this ?
I had this with my mates P30 Pro, the usbc charger wouldnt fit in correctly into the socket, I brought in some isopropyl alcohol, then used a tooth pick to clean it, took about 15mins to get every bit of dust out, even though it looked clean from looking at it, it was still stuffed with dirt.
worked fine in the end, keep trying to clean it.
Otherwise, a trip to Samsung shop and get it repaired under warranty
  • Like
Reactions: nam
