S4 & GPS issues.
7 Jul 2014
Peterborough
Hi
Galaxy S4 running kitkat just will not lock onto GPS.
GPS is turned on and i have also tried the following;
1. All GPS apps, none will lock on.
2. Checking the screws with the back cover off. None were loose.
3. Factory reset.
4. No Yahoo weather apps are installed.
I have also found the following and tried this...
Open the Phone, as if you were going to make a phone call and dial -
*#9090# -- Diagnostic Configuration (*#197328640# if that doesn't work)
Menu, select Key Input, enter Q
Menu, select Key Input, enter 0000
wait for the next menu. (It takes a while.)
UMTS->COMMON->NV REBUILD->NV REBUILD->SYSTEM->PROTOCOL->GPS->IMS
or, if you don't have UMTS:
UE SETTINGS & INFO->SETTING->SYSTEM->NV REBUILD->ALL
Restart the phone.
But I get stuck here..
UMTS > COMMON > NV Rebuild but then the only options available to me are;
1. Load Default NV
2. Erases All EFS1/2/3!
3. Make Back-up
4. Restore Back-up
5. Erase only Backup
Golden-Backup exist
You can Restore Cal/NV
I cannot get to NV REBUILD->SYSTEM->PROTOCOL->GPS->IMS
I know a few other people has this issue recently, but i just cannot get the damn GPS to lock.
Any suggestions as it used to work up until a few weeks ago, I suspect something has changed/updated.
Phone has also not been dropped :D
OK, bizarrely after a re-flash via ODIN of the stock firmware i now have GPS.
No idea what's happened but hope this may help someone else out in the future.
