S478 Thermalright Fan
24 Jun 2004
If I managed to get a new Thermalright SP-94 for my S478 P3.2, what would be the best fan for it? I dont care the price of a fan to cool it down as I know they dont cost much anymore.
Noise is an issue as I dont want the fan to be noisier than the stock fan I have running at the moment. Got the Thermalright SP-94 as im going to use the IC-7 Max 3 to overclock it as much as I can, and stock cooling just doesnt work well enough.
panaflo 80mm or 92mm
forget Akasa ambers with a p4, ok for when idleling but soon as it goes full load the Akasa wont cool much problay will melt lol
i had the sp94 heasink with a vantec stealth 92mm was ok for ideling but not full load iam afraid.
i read earlier your using an IC7 max3 are you sure a XP-90c wont fit ?... google it..
I think a XP90c performs better than an sp94 and i have had both.... its worth a look !
Someone was suggesting I get an SI-120 & Akasa Amber and to fit it in I could just remove the OTES that is blocking me fitting much in.
Would that be recommended?
