S80b silly question!
1 Aug 2006
This is for all the s80b people out there;
I couldnt figure out why my case temps seemed so high? After a bit of mucking around i took the 'cpu shield' off of the 120mm fan only to find it had been blowing inwards instead of out the case!!! :confused:
Is that a standard lian-li thing or was mine screwed together wrong? Just seemed strange unless thats what they wanted the top fan for; anyway my cpu dropped 10oC instantly,very strange
Any thoughts ....
Front in, rear 120mm and top 80mm out.
Mine came with the front fans blowing in and out, top was an intake and the rear was an intake.
Think nothing of it, the fans are rubbish anyway! :p
Personally I would prefer no fans and the price being £15 less. But we can not have it all.
Thanks again yewan - the fans do look like an after thought to me. Not very good when you consider the price!
What fans are you running in there now? Looking for some quiet - i have bought an 80mm papst and im looking into the scythe s flex 120mm for the front...
Still after a fan controller, but if not ill just drop the volts ;)
