s939 Crossfire system spec... your Thoughts?
As it stands... my PC is a bit of a mess....
I Found the cash for an X2 3800 a little while back,
Powered by an ASROCK 939 Dual.
Has 1.5gb of Kingmax DDR3500, and a Radeon 9800 SE AIW (yeh, those lovely hercules cards
PSU is Hiper Type-R 580w thingeh...
Since payday is nearly here again, I decided i really needed to do something about my system.
My Proposal is:
Antec SLK3000B Midi Tower Case - No PSU (CA-027-AN)
£34.06
Asus A8R32-MVP Deluxe Crossfire (Socket 939) PCI-Express Motherboard (MB-131-AS)
£105.74
Pioneer DVR-111DBK 16x16 DVD±RW Dual Layer ReWriter - (Black) OEM (CD-038-PO)
£25.79
2x Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II 16MB Cache - OEM (HD-078-SE)
£140.88 (£70.44 each) [For Fileserver not this box - A good chunk of storage is needed, but not nessecarily these drives if there's something better value for money]
HIS ATI Radeon X1900 XT ICEQ 3 SILENT Heatpipe 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-053-HT)
£234.99
Total: £541.46
This is really the top end of my budget, infact, its about £30 over, but i can go hungry for a few days
What i'd like from you wonderful folks, is thoughts on the capabilities & compatibilities of the system. Is it worth looking towards the Crossfire route in future, or are the cards likely to be unavailable before its nessecary? If you had my budget, and general requirements, what would you buy?
Im not as into overclocking as I used to be, but a little bit of extra power never hurt anyone
... the key factor is stability though.
)PSU is Hiper Type-R 580w thingeh...
My Proposal is:
£34.06
£105.74
£25.79
£234.99
Total: £541.46
.What i'd like from you wonderful folks, is thoughts on the capabilities & compatibilities of the system. Is it worth looking towards the Crossfire route in future, or are the cards likely to be unavailable before its nessecary? If you had my budget, and general requirements, what would you buy?
