S939 mATX
24 Feb 2004
St.Andrews
Hi,
Currently running my oldish (feels old anyway) Opty 165/2GB/7800GT in a v1000+. Nice case but kinda big & rattles a lot :(
Would rather like to dowsize but can't afford to go to c2d or quad core just yet.
What cases/mobos could you reccommend that will take the above gear?
PSU is 300W but it's a very efficient psu and would easily rate as 400+, my system at the momonet ticks over very nicely and that's with both the cpu and gpu oc'd. Bad news is there is no pci slot only pcie :( though in sayin that I have found the o/b sound spot on for gaming / music and movies with a 5:1 surround system.
with smart fan on the loudest thing i hear is my gpu ( as I've ramped the clocks up i upped the fan speed ) there are 6 preset fan settings in bios from shhhh you can't hear shizzle to whooosh I'm taking off in a sec
with it's lowest settings my hdd is noisiest thing in there ( I'm modding it to use rubber straps to remove hdd noise )
tbh I love it shoebox size with decentish specs, you can always pick up a X2 chip at a later date and they can accept 8800GT/GTS with slight internal case mods, PSU copes fine
yes indeedy, here's a spec taken from a site i don't wanna linky to may contain competitors etc
CPU support Socket 939-based Athlon 64 processors
Chipset NVIDIA nForce4
Interconnect NA
Expansion slots 1 PCI Express x16
1 PCI Express x1
Memory 2 184-pin DIMM sockets
Maximum of 2GB of DDR266/333/400 SDRAM
Storage I/O Floppy disk
1 channels ATA/133 with RAID 0, 1, 0+1 support
4 channels Serial ATA II with RAID 0, 1, 0+1 support
Audio 8-channel audio via VIA Envy24PT PCI audio controller, VIA VT1617A codec, and Wolfson WM8728 DAC
Ports 1 PS/2 keyboard
1 PS/2 mouse
1 serial
4 USB 2.0 (rear)
2 USB 2.0 (front)
1 Firewire via VIA VT6307 (rear)
1 Firewire (front)
1 RJ45 10/100/1000 Gigabit Ethernet
1 analog front out
1 analog bass/center out
1 analog surround out
1 analog rear out
1 analog line in
1 analog mic in (front)
1 analog headphone out (front)
2 digital S/PDIF outputs (RCA and TOS-Link)
1 digital S/PDIF input (TOS-Link)
BIOS Phoenix AwardBIOS
Bus speeds CPU: 200-250MHz in 1MHz increments ( note that with the Y revision bios this is actually up to 300 )
DRAM: 100, 133, 166, 200MHz
Bus dividers HT: auto, 1x, 2x, 3x, 4x, 5x
Voltages CPU: auto, 0.8-1.7V in 0.05V increments
DDR: auto, 2.7-2.9V in 0.1V increments
Chipset: auto, 1.6-1.7V in 0.05V increments
Monitoring Voltage, fan status, and temperature monitoring
Fan speed control CPU, system
That's the SN25P as far as I'm aware the SN26P is exactly the same with only the addition of and SLI capable mobo
*ninja edit* as audio is a big concern of yours I dug this out for ya, tbh it's all randomness to me but sure it'll help you
Shuttle hides the FN25 motherboard's most interesting feature up in the top corner of the board. Here, we find VIA's Envy24PT audio controller, VT1617A codec, and a Wolfson WM8728 DAC. With support for 24-bit audio at sampling rates up to 96kHz, the Envy24PT hints at high-definition audio, but it's not quite that easy. With analog output, codec and DAC sampling rates and resolutions also come into play, and that's where the SN25P's implementation falls a little short. The Envy24's first six output channels are routed through the VT1617A codec, which only supports resolutions up to 20 bits and sampling rates up to 96kHz. The Wolfson DAC supports 24-bit/192kHz audio, but in an eight-channel configuration, it only handles channels seven and eight.
It would be wasteful just to use the high-end Wolfson DAC for channels seven and eight, but VIA's Envy24PT drivers actually allow users to route two-channel stereo audio through the WM8728. This pipes stereo output through the SN25P's rear 7/8 audio output, potentially offering superior fidelity to the VT1617A. At the very least, the driver switch allows users to enjoy two-channel 24-bit/96kHz audio output through analog speakers or headphones without having to worry about downsampling sapping fidelity
If you want to go micro ATX with something like a Lian-Li V300+ or Silverstone Sugo SG01 or SG03, then your best bet is to look second hand for the motherboard, as it's going to be tough to find a good one new.
Personally i'm a big fan of DFI so i'd recommend their RS482 board over all the other mATX S939 ones, but I also believe there's a Biostar board that performs well too. And EVGA even have an SLi S939 mATX board... if that kinda thing floats your boat! :D
939 mATX boards to look for are
Biostar T-Force 6100-939
DFI RS482 Infinity
Foxconn 6150K8MA-8KRS
A8N-VM
A8N-VM CSM/NBP
A8N-VM CSM
GigaByte K8N51GMF-9 S939
GigaByte K8NMF-9 Socket 939
MSI K8NGM2-IL NF410, S939
but there all gonna be hard to find new now days
OcUK sell the Asrock 939NF6G-VSTA Micro-ATX s939 board (with PCI Express) for about £50. On-board Nvidia 6100 graphics if you don't want to buy another card though the x1950 pros seem to be decent price these days if you need decent gaming performance.
What about one of the Antec Micro-ATX cases? The 3480 for tower or 2480 for desktop? 380W power supply but I'm not sure about the quality. The Thermaltake LanBox look interesting if you want to spend a bit more/go Shuttle-like look.
