Sabertooth 990fx usb3 header question.
13 Jun 2011
Glasgow, Scotland
I have a corsair 600t and if anyone knows this case then you know the usb cable is effectivly an extension to the front.
Does the board have something that you attach to the header to give a regular usb3 port or do i need to order this as an extra?
I use a portable usb3 drive to swap large files about between computers and while i could live with the usual usb2, i'd rather not.
Cheers
Edit: After watching several reviews i see it doesn't come with.
I know some ASRock mobos came with a 3.5inch sized front panel but I've not seen Asus include anything.
If your case doesn't have USB3.0 either then you'll need to buy a 3rd party front panel, it might be worth checking with Corsair first though because some case manufacturers have released upgrade kits.
