Sabertooth 990fx waterblocks
There are no full cover water blocks for this motherboard ie NB and mosfets.
EK do a NB/SB block, EK-ASUS NB/SB 1 [3830046991058] or EK-ASUS NB/SB 1 - Acetal [3830046991065] which will fit the Sabretooth northbridge and any AMD compatible CPU block should fit.
Fitting only the northbridge would probably require modding other heatsinks over the mosfets and may not be easy or ideal.
Definitely not worth switching to nb wcing if it leaves the VRMs bare. There is a heatkiller kit which can be cut to fit most VRM setups.
If you were really looking to watercool your motherboard the Crosshair V Formula Z has an EK block for the nb + VRMs. I have this board and the block and they are great!
