SABnzbd nzb reader
4 Oct 2004
Hi guys, im new to mac osx, and was wondering if some kind soul would show me how to set up this program to download nzbs' i can get them to queue, but i dont see how i can download them?? im probably being thick though :P
Once they are queued they will download automatically. Check you have your server address right etc. Also if you are using ssl you will need the latest version otherwise it wont work.
Im sure its an amazing program but seems very complicated. Maybe its just me though, bit tired atm will try again tomorrow.
Something which is bothering me is this:
Host:
If you are just accessing SABnzbd from the pc it is running on, you can leave it as "localhost".
If you want to access the web interface from other PC's you can:
* Leave it blank to have it automatically find your external IP
* Enter in your machines local ip address if you know it
* Enter "0.0.0.0" to listen on all interfaces including Localhost (recommended if you are having problems)
Web username and password:
If you want to secure the web interface from prying eyes, set a username and password here (warning this is only simple authentication). When you next restart SABnzbd you will be prompted for the username and password before you can use the web-ui.
Does this mean it automatically sets itself up to listen for connections to log in to control the program from the internet? I would have thought this was disabled by default? Does it mean it is disabled when it's set to localhost and nobody can connect? Thanks in advance.
Ya, you have a point there Graeme. Ill check to see if its turned off by default tonight. Could be a bit of a security issue if it isnt.
