SABnzbd+ scheduling speedlimit question
2 May 2004
I've decided to use the scheduling built into SABnzbd+ rather than Netlimiter just to lighten the load on my server a bit - Netlimiter is only used for SABnzbd+, so there's not much point in it.
I've now set a speed limit on SABnzbd+ between the hours of 9am and 2am.
At the moment SABnzbd+ is limited, as it should be - to 10KB/s. However, Netlimiter is reporting hardly any activity on SABnzbd+ - sometimes a couple of KB/s, something absolutely nothing. SABnzbd+ is telling me it's downloading at 10KB/s.
So basically when SABnzbd+ uses it's own limiter it reports at 10KB/s, but Netlimiter only reports it at 0-~4KB/s. Which should I be trusting?
[Edit]
That's odd, just did an extremely technical test & watched part of a Usenet download coming through. Counted how many seconds there was between the refreshes and took note of how many KB had been downloaded. The refresh was 40 seconds and it had done roughly 400KB, so it's running at the correct speed.
I'm a bit confused as to why NetLimiter isn't reporting SABnzd+'s speed properly since I implemented the schedules within SABnzbd
Any ideas?
Thanks,
Craig.
