You might be missing something;
Command + : and change the language in the menu and see if that fixes it.
Works fine for me...
Edit > Spelling and Grammar > Show Spelling and Grammar.
DoublePost: I'm using Webkit. Works in Safari.
Works in WebKit for me... Got the latest build?
Stop double posting like a nub moneky.![]()
Try being a mod on phpbb3, edit button is where quote should be, and delete it next to edit!
If you are using Safari then you don't have to highlight the word, all you have to do is right click on the word and click "Look Up in Dictionary" as Safari highlights it for you
As for the British spelling, to correct this, go to System Preferences then International. From here, click Edit List and tick British English which should now be on the top of the list. The British spelling now should be correct![]()
