safari and remember me in ocuk forums?
28 Jul 2004
Hi,
When i try to sign in to the OCUK forums using the remember me option i just get a blank white screen. It works fine if i dont use that option. Is there a way round this?
I'm using the latest safari, but I've only just got my macbook so don't have any idea if this was the same on earlier versions of safari.
cheers
I've never had this issue. Install all the updates available if you havent already. If that doesnt work, go to Safari > Reset Safari and see if that works.
On a somewhat related note, if you are not offered the option to save your username and password in your keychain where you would usually expect to be able to do so (and I think vB forums like OcUK have this annoyance by default), create a new bookmark and add the following as the 'address'. Next time, click the bookmark before you log in and you will then be offered the option to save your login details in the keychain when you submit.
Code:
javascript:(function(){var%20ca,cea,cs,df,dfe,i,j,x,y;function%20n(i,what){return%20i+%22%20%22+what+((i==1)?%22%22:%22s%22)}ca=cea=cs=0;df=document.forms;for(i=0;i%3Cdf.length;++i){x=df[i];dfe=x.elements;if(x.onsubmit){x.onsubmit=%22%22;++cs;}if(x.attributes[%22autocomplete%22]){x.attributes[%22autocomplete%22].value=%22on%22;++ca;}for(j=0;j%3Cdfe.length;++j){y=dfe[j];if(y.attributes[%22autocomplete%22]){y.attributes[%22autocomplete%22].value=%22on%22;++cea;}}}alert(%22Removed%20autocomplete=off%20from%20%22+n(ca,%22form%22)+%22%20and%20from%20%22+n(cea,%22form%20element%22)+%22,%20and%20removed%20onsubmit%20from%20%22+n(cs,%22form%22)+%22.%20After%20you%20type%20your%20password%20and%20submit%20the%20form,%20the%20browser%20will%20offer%20to%20remember%20your%20password.%22)})();
