Safari? media problem?
The file you are trying to access cannot be found.
Das angeforderte Dokument konnte nicht gefunden werden.
That's what I get, the video isn't even there. I have no idea how your windows friend is able to view it :confused:
thats the same thing im getting mate when I open a new tab from the Broadband link. Not sure what my mate is getting, he said it opened up on the same page on the site :confused:
It works for me in Camino - just been watching it now using the Broadband button.
Wouldn't work in Safari though, I couldn't get the Broadband button to even register a click.
why do you guys prefer firefox over safari?
safari works really well and looks great
I used Firefox on Windows, and as you can get a version for the mac i thought why bother with change, i dont like change, especially loose change :(
How you actually install firefox on the mac :p? There is a mounted disk when I use it? is there a way to install it permanent or is the way macs work?
You might want to read the FAQs...
Here's a clue : do as suggested in the backdrop to the DMG - Drag the app icon in the disk image to the Applications folder.
Bingo! - it's then installed... It's the standard Mac method of installation.
