Hello all,
Lion os x Safari 5.1.2, i used to use my trackpad and (single finger) double tap next to an open tab to create a new one. For an unknown reason i can't do that now, and can only right click next to the tab to create a new one. I've been through all settings that i know of that can change it, but no luck.
Can anyone help with what maybe the cause as i've not done any updates of which may have caused the problem, is there an other settings i can adjust that you know of?
Thanks in advance.
Av8
Thanks in advance.
Av8
