- 29 Sep 2004
hi guys, wondering what you'd consider a safe voltage for an overclocked 8400 (4ghz atm), E0 stepping
the VID is 1.2500v
am currently using orthos at 1.4v (bios) 1.392v (CPU-z), seems to be hitting 60c after 30mins of Small FFT's stress testing under a Freezer 7 pro
thanks
edit: as well as your maximum safe voltage, what would you consider your max temperature?
the VID is 1.2500v
thanks
