- 13 Dec 2021
- Planet Earth
Hi,
I just bought a workstation dedicated to 3D graphic design rendering work, and I'm a bit frustrated because of my cpu current frequency: it's an AMD 3990X and its frequency is actually stuck at 3.1GHz which is not that bad, but way below what I was expecting.
I read on AMD website that this cpu has a "Max. Boost Clock of Up to 4.3GHz" ... so my question is: how can I achieve that?
I guess it has something to do with enabling PBO so I went into the BIOS, enabled it, set few parameters to the maximum allowed (Max freq offset: 200 MHz ...), but ... still, there's barely no difference whether it's on or off when running Cinebench R20
(score: 23700)
So I'd highly appreciate if you guys could tell me few hints on how to SAFELY go beyond the 3.1GHz frequency my cpu currently runs at. And by safely, I mean I want to set the frequency higher but not to a point where it can damage my cpu on the long term. This cpu is a costly one, and I want it to run safely for years to come
One small additional question, which I think is kind of related to the first one: CPU-Z x64 says my RAM frequency is 1333MHz. Is it normal? As it's RipJaws DDR4-3200?
Here is my machine specs:
* ASUS PRIME TRX40-PRO S
* AMD Ryzen Threadripper 3990X
* Noctua NH U14S TR4-SP3, push-pull configuration (with one additional fan)
* Case: Be quiet! Silent Base 802, with 5 x be quiet! Silent Wings 3 140mm Fans
* RAM: 128GB G.Skill Ripjaws V 3200MHz (4x32GB | 16-18-18-38)
* PSU: Corsair AX1600i
* MSI RTX 3060 Ventus 2X OC - 12GB
Thanks a lot in advance for your help, much appreciated,
Tim
(score: 23700)So I'd highly appreciate if you guys could tell me few hints on how to SAFELY go beyond the 3.1GHz frequency my cpu currently runs at. And by safely, I mean I want to set the frequency higher but not to a point where it can damage my cpu on the long term. This cpu is a costly one, and I want it to run safely for years to come
)One small additional question, which I think is kind of related to the first one: CPU-Z x64 says my RAM frequency is 1333MHz. Is it normal? As it's RipJaws DDR4-3200?
Tim
