Hi Guys,
Just wondering what would be considered safe temps for a 8800gt OC?
Currently the card is at 670/975(1950)/1675 and is idol at 47 and 60 max under load. So should I push a little higher? What are the sort of max limits for 8800gt overclocks?
Also, using nTune, when you set the fan control manually, that does mean the fan still increases as the card goes under load right? I mean, if I set it to 45%, will the speed increase as the load increases still or will it just stick at 45% regardless of load?
