safe mode on the pw5 DH
2 Feb 2006
Barnsley & Jordie Land
How do get in to safe mode on this motherboard, ive been pressing F8 like a mad man but i can not get into it.
If you are talking about Windows Safemod its is F8 regardless of what motherboard you have.
If you have a USB keyboard you might have to change USB keyboard handling in the BIOS so that you have a working keyboard before Windows is loading.
Think its usually called something similar to legacy USB or something like that.
if you mean safe mode to boot and get into the bios after a failed over clock press insert while powering on the machine.
Also if you fail to get in after a few attempts it boots into default values anyways,
If windows as said, hit f8
windows safe mode so i can do driver update and run drivercleaner but i must be missing or doing something wrong because no matter how many times i press F8 it continues to boot up into normal windows. ive look at bios setting for the keyboard and thats set up rite. :confused: . Amd was a lot easy still dont no how to OC :eek:
Do you use USB or PS2 keyboard?
I know if I flash my bios on my old Asrock Dual Sata 939 board it changed the USB keyboard handling and I cant get F8 to work without changing it as the keyboard isnt working untill windows loaded.
