Safe temp for the PWMIC temp monitor?
Caporegime
7 Nov 2004
Buckinghamshire
Hi guys,
Sorry for the silly question....But whats a 'safe' temperature for the PWMIC reading in Smartguardian?
Just thought id ask, as im interested, and dont like the temps i have on it =/
Thanks.
Hmmm ok..Had to ask, was running a test on my gpu, and smartguarding had it at 45 degrees, but it was red.
So hey, better to be safe that sorry =D
Hmmmmmmm...I put my freezer back on today (did have a tuniq on there) And the Pwmic temp is like...idling at 42....
It used to be sooooooo much lower =/...I really dont get it?
I have a lian li v1000 case, with a kama bay at the front blowing in, a freezer 64pro on my cpu, and a yateloon at the back...Any ideas on how i can get it lower is appreciated, or should i just leave it and see how it is after gaming etc?
What board are you using Delvis?
I used to use a DFI SLi DR and the PWMIC got to 70 degrees C (full load) with a Scythe Ninja (which didn't blow over the board) however a quick change to a lapped Thermaltake Big Typhoon sorted the problem by cooling my Opteron 165 @ 2.8ghz better than the ninja whilst also blowing over the motherboard to bring PWMIC temps down to 45 degrees C under full load! Awesome! :cool:
gt
Ah its an Asus A8n-sli premium board...
I might have to look into a BigT quite frankly...I'm just not too keen on the mounting mechanism.
Hey, sorry to revive the thread...I've sorted out the temp issues, i just moved my kama bay up one slot, and now it cools the chipset thats under that passive cooler thing. Seems to work :)
Oh and i switched the scythe fan for a yateloon, which seems better...As theres actually airflow coming from the bay now :P
Nice!!!
Good job! Yeah the Kama bays fan is quiet but if you need high airflow they're not the first choice.
gt
Yeah, i already had a yateloon there before the kama bay...just i wanted it to look a little less 'bodged' :P
I'm just debating whether or not its worth putting the tuniq back on....see what happens.
Maybe tommorow, i've just recabled my system so i cant be bothered to do more to it!
