Safe Temps After Overclocking?
17 Jan 2015
Hi there,
I've just overclocked my system for the first time (from 3.5GHz to 4) and am slightly concerned about the CPU temperature readings while running software (Premiere Pro).
The idle temp is usually around 40 and when running software like Premiere it is anywhere between 44-75.
I am wondering if these are safe temperatures or if something may be wrong with the system?
If it makes any difference my case is quite full and could be bigger (Corsair 200R).
Here is a screenshot from AI Suite - perhaps something here is awry?
Any thoughts are hugely appreciated.
Many thanks...
System:
i7 5930K
Asus X99-A
GTX 970
Noctua DH-14
32GB DDR4 RAM
AX 1200i
As above, keep it under 80c under max load and you are golden. The only other thing to be aware of is your max voltage, but it looks like you're already playing it safe with that.
