Since updating to a full custom watercooling solution I have been experimenting with various settings to try and get the highest clock with a vcore that I think is still in the sensible range.
Currently I have settled on 4.8ghz @ 1.36 vcore under load. I did an 8 hour prime run (blend) and the temps maxed out at 56°. So temp wise I am happy. I know that over volting your cpu shortens its life expectancy but is it relatively safe to keep it at 1.36 24/7. Due to various issues all of the power management options in the bios C1E, EIST etc are switched off.
On MSI boards you don't get offset (running a P67 GD65 rev B3) so the only way to get vcore to lower when idle is to set voltage to auto and that yields crazy voltages when underload.
