I don't see how quads can be changing the laws of physics here though?!!
If somebody more knowledgeable than myself could explain things, then I'd be grateful!!
Sure there is a greater quantity of heat being produced, because there are twice the amount of cores than before, but assuming your chosen cooling solution is up to it, they shouldn't in theory run appreciably hotter than a standard core2?
I've noticed that temps creep up a degree or two on my pc's when they've been working all day, so I think that's normal and not just a quad thing. Other things in the case soak up heat and then radiate it and of course generally the room gets warmer too as the pc's churn out hot air.
To be honest, I think the quad hot running thing is being reported a bit hysterically at the moment, similar to the good old 2900XT...
I'm picking one up myself tomorrow, so I'll find out for myself!!
Yes, they run a bit hotter, but it's not by much, and anyway they've been designed to cope with it.
But then we knew that already didn't we?!
