Safe Voltage for E6600
6 Apr 2007
Manchester
Hi,
I am just putting my water cooling bits together :) on air my E6600 does 3.5Ghz with 1.425 vcore, now that she will be going under water what are safe voltages as temps won't be too much of a problem any more?
Thanks
If you're stress testing using Prime/Orthos then temps will still likely be the limit. You'll probably find once you hit about 1.5-1.525V that you'll hit the temperature wall again.
Jokester
For benching I have gone upto 1.65v but I wouldn't recommend that for 24/7. My current setup is 3.9ghz with 1.52v. My previous was 4ghz with 1.6v.
iirc Intel have recommended a max vcore of 1.5825 (although there boxes say 1.35).
You will find that clockspeed and/or vcore will increase temps and any increase in either of those is 'risking' your cpu and definately shortening its lifespan - how much by nobody knows and as every cpu will be different each risk is also different - it is purely a best guess scenario and how much YOU are willing to push it, nobody can tell you how much is safe as the only safe setting is a stock setting.
You'll often find that there comes a time when you start having to pile loads of volts to gain marginal speed....this is where you draw the line ;)
