I have my 5820k running at 4.4GHz atm with a Vcore of 1.3625v
Max temp running Real Bench is around 70c and seems 100% stable
I'll hopefully get the 70c down when i replace all my 120mm fans with Noctua NF-F12 PWM's
My current setup with H100i mounted to top of case:
Is 1.3625v a safe voltage to run 24/7 with my current setup?
I was hoping to get 4.4GHz with lower volts but i just get BSOD's running Real Bench.
My Bios Settings:
Vcore: 1.3625v
CPU System Agent Voltage: 1.18125
CPU Cache Voltage: 1.25
Memory @ 2688MHz - 16 16 16 39 2T
My Real Bench score is 104,147
Can i push Vcore even further to try and reach 4.6GHz or beyond?
Just want to make sure i don't damage anything, and im a bit unsure about safe 24/7 volts for these new x99 processors
Any help is appreciated!
Thanks.
Nick
My Bios Settings:
Vcore: 1.3625v
Thanks.
Nick
