Hi Folks,
I am in the process of overclocking my new Q9550 but am a bit unsure of the voltages I should use.
Currently it is running at 473x8.5
CPU volts are 1.248 in CPU-Z under prime 95 small FFT load
I have my Northbridge set to 1.3575 and my VVT set to 1.32.
What I did when I first overclocked the chip was just wack all the voltages up to get to 4Ghz and now I am reducing them slowly to get a low voltage and keep the cpu stable.
I'm pretty happy with the temps I am getting at these volts and clocks (the hottest core hasn't gone about 53 and the lowest 48) so I may try push it a bit further buy 470mhz enough I think for day to day running. CPU is currently being cooled in a custom water loop with my GFX card.
What voltages do you use for your Q9550s?
