2bullish said:As it states Im currently running at 51 under load. My ambient temps are 34 at idle. Im running an arctic freezer 64 pro, with the fan at the front sucking in and the one at the back blowing out.
My case is a Antec SLK3800B which has another side hole for a smaller fan, I want to add a fan here as I think my ambient temps are high, should this be blowing air over the cpu or sucking warm air out?
The cpu cooler is facing outward blowing air through the fan thats sucking air out of the back, is that the best way?
Also my temps idle for the cpu are 38, I think thats high am I right ?
2bullish said:Unfortunately I cant go past 250 htt no matter what I do, I seem to be hitting a wall after that. It cant be my mem as Im running a divider, not sure what the bottleneck is
Hard to apply? Comes pre-applied on the base of the HS :/Cyber-Mav said:MX-1 is too hard to apply. wasted half the tube trying to apply it to a gf4 core.
i just use coolermaster/arctic cooling/akasa white thermal paste which is easier to spread. can;t be asked with all the hassle for minor drops in temps.
2bullish said:Strike that, I had my freezer pro the wrong way round, temps just dropped by 6 degrees
Actually sounds more than that..TaKeN said:Hmm sounds more to me like you reseated it a bit better
Thats why the temps have dropped
