Sag bracket for 3080
6 Dec 2007
Cambridge
Hi all
I've got a Palit 3080 GamingPro, which includes an acrylic sag support. Unfortunately it's quite chunky and won't fit under my pcie screw cover.
It doesn't look like it's sagging, so do you think I really need it? I've got 2 bottom fans, so a conventional stand might not work unfortunately.
Thanks!
Hi all
Thanks!
Use Legos :D
No idea of the pallit's bracket, but my MSI one was designed to go over the cover plates at the back (but using the screw). maybe yours does to ?
Sorry - photos would have helped!
I've had the card installed since lunchtime and it doesn't look like it's sagging so far. I've left it off as I think the gaping hole in the back is probably a bigger issue.
It's not the best piece of design - about 7mm thick. It's a tight case, so I don't think I could even mount a stand in the bottom of the drive bay.
