Morning guys,
We're trying to quote on a server install, and have realised that the competitor has provided a solution that physically cannot work:
Physical Server: HL ML350 G6 (Dual Xeon E5520 @ 2.26GHz, 16GB, 4x 146GB, 4x 300GB) running Server 2008 R2 with Hyper-V running as DC, File & Print, Exchange 2010.
Virtual Server: Server 2008 R2 running SQL 2008.
From what i've seen:
Exchange needs to be spread over at least 2 servers (Hub+CAS, then Edge on a separate server). So you think fine, put one of the roles on the virtual server. Except the below states you can't:
So we were planning on the following:
Host: SBS 2011 Std
Virtual: SBS 2011 Premium Add-On (ie Server 2008 R2 + SQL 2008)
So my question is this, is Sage 200 supported on our proposed solution?
I phoned Sage, but they got stuck up on the fact i mentioned SBS 2011 which isn't supported (as you'd expect, as SQL needs to be on a separate machine).
Useful Facts:
Currently only have 11 users. Planning to expand slightly soon, but nowhere near the 75 user limit for SBS.
http://technet.microsoft.com/en-us/library/aa996719.aspx said:Only management software (for example, antivirus software, backup software, or virtual machine management software) can be deployed on the physical root machine. No other server-based applications (for example, Exchange, SQL Server, Active Directory, or SAP) should be installed on the root machine. The root machine should be dedicated to running guest virtual machines.
Host: SBS 2011 Std
Useful Facts:
