So, I got bored with my Danger Den case. Didn't rate the built quality - a lot of screw holes didn't line up.
So I went with a case where the quality is top notch - Lian Li. The PC-A70F to be precise.
So, it was again time to put this lot of hardware from my bench table, into the new case:
Hardware consists of:
I7 2600K
Asus Maximus IV Extreme Rev.3
2x4GB Gskill RipJaws
Corsair AX1200
3 x GTX 580s
Asus Xonar Sense Soundcard
OCZ Vertex 3 120GB
Samsung 500GB 2.5" HDD
Cooling wise, I went for a single loop, cooling the CPU, Motherboard and 3 580s with an EK 420 and 240 rads. Dual DDCs to keep the flow nice and high
So, first things first. Powercoated the internals black. Custom bracket to mount the 240mm rad in the front, and mounted the 420mm rad in the bottom:
Quick trial fit of the new front panel:
As you can see, gone is the standard slats, cut out and replaced with some black mesh.
Also the modded fan controller, but more on that later.
I7 2600K
Corsair AX1200
3 x GTX 580s
OCZ Vertex 3 120GB
