Hi All,
need a partner who is decent at saints row to do the following with me, just send me a FR:
and
Apparently they don't take long and are worth 20gps in total
Ta
Bulletproof - Complete Co-op level Turbulence at the highest difficulty level. - For this simply go to "Xbox Live" than "Create Party" and select "Co-Op" on "Kingpin" Difficulty. You NEED 2 players to do this and once you finish the level you will get the achievement.
and
rrand Boy - Complete Co-op level Mob Rule at the highest difficulty level - Same as "Bulleproof" just select the "Mob Rule" level instead of "turbelence" In this one you must deliver 2 boxes to a location and they will respawn if left unattended for more than 30 seconds.... kill enemies, deliver boxes you're done
Ta
