Saitek eclipse 2 help
11 Aug 2004
Hi,
My calculator fell on my keyboard and messed it up, can anyone please take off their spacebar key and show me how it should look because I don't have a clue :(
I'm currently pushing a pen into the slot to space! :/
Thanks!
Clip the metal thing into the spacebar as shown in pic then just put the hooked bits into the plastic hooks on the keyboard and push it into place if you have not put the metal hook into the plastic hooks properly then the spacebar wont fit straight.
if your clips broke like mine did, just have to send an email to saitek and they will send you a brand new spacebar.
