Saitek Eclipse 2 Replacement
10 Mar 2011
I had the original Saitek Eclipse and then the eclipse 2 which has finally given up after 8 years
I purchased the Corsair Raptor K30 as a cheap replacement but found that the key caps are raised off the base (about 1cm), because I use the cursor keys to control movement I am finding it difficult to maneuvre by fingers, it may just be because I'm used to key caps that are almost flush to the base
Are there any recommendations membrane or mechanical where the keys are flush to the base similar to the Saitek Eclipse for around £40 - £60?
