saitek eclipse 2
21 Jan 2008
England
anybody have this keyboard?
my problem:
Its a very good keyboard, well put together and seems very solid with nice keys. BUT, there is one small problem which for me, makes this keyboard unusable. Some of the keys are very unsensitive and take more pressure to make them respond. As i play a lot of fps this is a bigg problem. Is there anything easy i can do to fix this? before i sell it:(
thanks..
I have the keyboard and can't say as i have noticed the problem you are having. Even when mine was brand new out of the box all keys were responsive. Are they getting more responsive the more you are using them ? if so maybe they are just very snuggly fit and need loosing up a bit.
When i first got this keyboard i had this problem aswell, specifically on the 's' and 'd' keys, which really annoyed me as an fps player. After a day or two of using the keys seemed to have loosened up and have been working fine for over a year now.
I had this keyboard, and yep same problem after about 6 months of use.
Can't remember which keys exactly and I RMA'd it.
Excellent keyboard, but I got the Saitek 1 for a good price and apart from the crappier looks its identical in performance.
+1 - can't fault it..
It'd be nice if you could choose a default colour, so it's red from boot..
