Saitek Farming Simulator Controller
31 May 2005
Nottingham
http://www.saitek.com/farmsim/
Saitek and GIANTS Software are teaming up to create the first ever, custom Farming Simulator hardware! Forget about using racing wheels to play Farming Simulator, you'll be driving your vehicle with a properly tilted, center sprung steering wheel with 900 degrees of turning and a wheel turning knob—just like the real thing! On the wheel, a Mini-stick controls your movement when not in your vehicle and real buttons allow you to use your in-game PDA. Gas and brake pedals come standard with the wheel, too.
Most exciting of all, Saitek is developing a Vehicle Side Panel exclusively for this game! The Side Panel features a Front Loader Control Stick to give you precise control of your vehicle's front attachments and fully programmable buttons for tool attach/detach, tool switching, reverse, lights, horn, cruise control, and more!
These are just some of the features under development for the new Farming Simulator hardware. As development rolls on, Saitek and GIANTS will periodically ask the community for its opinion on certain design features should and design decisions.. We'll also give you peeks behind the curtain with regular developer info and product progression updates on Saitek.com so check back frequently!
