- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Saitek's answer to the Logitech G940 flight stick is available to pre-order. The Saitek X65F controller will allow you to dog fight better than Tom Cruise in Topgun.
Saitek X65F Pro Flight Control System @ £349.99 inc VAT
Rule the skies with the latest Saitek X series controller – the Pro Flight X65F Control System. Custom engineered from high grade metal castings, this is a system that is built to withstand many combat engagements. The number of controls available will cater for any pilot’s needs, but the true innovation resides within the stick itself – Force Sensing technology.
- Metal construction for the ultimate in realism and durability
- Unique force sensing stick - all input is detected from how hard you push on the stick, just like in real modern day jet fighters
- Features on-the-fly adjustment of the force settings for the stick - including separate adjustments for each axis of the stick for the ultimate in stick response configuration
- Dual throttle for finer control over twin engine jets, or lock the two throttles together for single engine fighters
- Force-sensing twist rudder control
- Controls featured across both the stick and throttle: 8 x 8-way hats, 8 x buttons, 2 x rotaries, 1 x mouse hat, 1 x 2 way switch, 1 x scroll selector, 1 x 4 position mode switch - that's a potential total of 608 commands possible without ever moving your hands from the controls!
- Back panel with 5 more control switches, force-sensing strength selection, mode indication and mounting points for Saitek Pro Flight Instrument Panels (sold separately)
Only £349.99 inc VAT.
ORDER NOW
ORDER NOW
